560 teledepth valve
Ronald
04-01-2006 15:44:31
I can't get my 560 fast hitch to work right with the valve. When I got it the linkage was unhooked and a roll pin was sheared in the rocker arm going from the valve down the the top of the transmission case. First how do you get the arm coming off the valve going to the control valve handle on the splines the right direction, I couldn't find and marks to line it up and it will go on in any position. And also does the arm coming off the valve that goes back to the hitch face forward of backward, This pin was sheared and I think it goes backward but I'm not sure.
Thanks Ronald
trulyred
04-01-2006 17:34:09
 Re: 560 teledepth valve in reply to Ronald , 04-01-2006 15:44:31
With the problems you have stated probably the set of gears inside the cap on the end of the valve are stripped or sheared. You will need to take the two 3/8 capscrews out to remove the cap, if you don't see any damage you might be able to wind the shaft where arm goes to cause the spool to go into the valve and then set the arm to "fit" the linkage. Anything bound up can shear the pin or damage the gears which are timed, they should be marked.
