Where can I get Tel-A-Depth parts for a 240U?
240 ed in Wi
04-02-2006 01:14:58
I bought a 240U that had sat for 8 years. Got it running(valves were stuck and clutch was rusted to flywheel). I want to start using it now but someone with a big hammer busted up the Tel-A-Depth. The only thing left is a busted quadrant support so I need everything from the quadrant support all the way out to the handle. I also need the shaft that goes thru the seat support from the handle to the walking beam because they busted the end of it off where the roll pin goes thru. Everything on the left side of the seat base appears to be fine.I put a vice grip on the shaft this morning and was able to get the fast hitch to go up and down like it should so that made me feel better. If I can get the parts that are missing this will be a nice little tractor.Also, was the fast hitch available without the Traction Control? Mine has the fast hitch but the only part of the Traction control that is on the tractor is the cam on the front of the hitch. Thanks for helping.
rodowen
04-02-2006 08:47:54
 Re: Where can I get Tel-A-Depth parts for a 240U? in reply to 240 ed in Wi, 04-02-2006 01:14:58
This is the part number I got from Vestal IH/Case
522912r21
Hope this helps!!
Thanks a lot
rodowen
04-02-2006 06:58:21
Hey Ed in Bland,
Would yu perhaps have a stabilizer pin/bracket for a 230 in the midst??
Mine broke and can't seem to find one. Any help would be great!
Edin Bland
04-02-2006 07:18:14
 Re: Where can I get Tel-A-Depth parts for a 240U? in reply to rodowen, 04-02-2006 06:58:21
I think I know what you want, do you have part No.? Ed
rodowen
04-03-2006 05:36:46
 Re: Where can I get Tel-A-Depth parts for a 240U? in reply to Edin Bland, 04-02-2006 07:18:14
522912r21
Hope this helps!!
Thanks a lot Didn't know if you caught the part number or not. THanks
EDin BLAND
04-02-2006 06:01:31
Hey Ed, If you can get access to a parts book and send me a list of numbers for the parts you need, I think I have most or all of them. email me at edburnette2003@ yahoo.com. I'm In Virginia
