Intertube size
Andrew Betzner
04-02-2006 09:51:45
I have a 11x38 W drive rim for a farmall H. My tire is a 12.4x38 I was wondering if anyone knew what intertube size i needed.
gene bender
04-02-2006 10:37:33
 Re: Intertube size in reply to Andrew Betzner, 04-02-2006 09:51:45
just get tube for the tire size you have
Andrew Betzner
04-02-2006 10:51:43
 Re: Intertube size in reply to gene bender, 04-02-2006 10:37:33
That's what i was going to do but when i got there they had all these crazy numbers that were for tube sizes that didn't show what tire size it was for...
old
04-02-2006 11:38:50
 Re: Intertube size in reply to Andrew Betzner, 04-02-2006 10:51:43
You will find tubes are marked sort of like this. 11.2-13.6X38 which means that tube will work in any tire from 11.2 up to the 13.6 and any thing in between some tubes cover a wider range that is just an example.
CNKS
04-02-2006 11:34:51
If you went to a tire place that sells farm tires, it should be automatic for them to know the sizes. As Gene says get the one for your tire size. The same tube will fit different size tires, even different diameter rims, within reason, thus all the numbers on the tube.
