super c hyd pump
R Fink
04-02-2006 14:10:31
reassembling super c engine mounting hyd pump, what seals pump to engine block. Where is the pointer for the flywheel timeing mark
Bill Geer
04-02-2006 16:12:09
 Re: super c hyd pump in reply to R Fink, 04-02-2006 14:10:31
R Fink Pull the clutch cover off. Look on the in side you will see where it comes to a point. Cover has to be on to time. When you are in there find the mark on flywheel and put some white paint on it with a tooth pick. I did this 2 days ago/
Bill
El Toro
04-02-2006 15:17:08
I think there's an indicator on the clutch housing
cover I don't think it's a pointer. When you bring No1 piston to TDC on the compression stroke
your timing marks should be very close. Both valves on that cylinder should be closed too. Hal
