International 300 flywheel
Jared Chaddock
04-02-2006 16:21:37
I am rebuilding an International 300 utility and need to find a flywheel for it. The pilot bearing in the original must have siezed up at some point and spun the bearing in its bore, loosening it up, so it drops right thru now. I am told that a super H or a 350 uses the same flywheel...Does anyone know? Also, does anyone know where I might find one? Or possibly a remedy to fix the old one? Thanks in advance
Jim J
04-03-2006 16:34:53
 Re: International 300 flywheel in reply to Jared Chaddock, 04-02-2006 16:21:37
The SH flywheel is different than a 300 or 350 gas flywheel. The bolts that hold the pressure plate are 5/16 on the 300 and 1/2 on the SH.
the tractor vet
04-02-2006 17:02:01
Before i would go on the hunt for a flywheel i would take it to a machine shop and have them bore it with a step bore and amke a reapir bushing and have it pressed in to take the OEm bearing and be done with it lot faster and a bunch cheaper.
Nebraska Cowman
04-02-2006 17:01:36
have you tryed roughing up the bore with a center punch?
Nickmn
04-02-2006 16:30:02
Give me a email at cubng70@hotmail.com We have lots of used ones around in good shape.
