Sounds of farming
Charlie M
04-02-2006 17:18:16
What are the sounds of farming that makes you stop to look. Even though I don't own any green tractors I like to hear the old 2 cylinders at work. I also like to hear the sound of the 6 cylinder engines used in the W40 and 460/560. Those old engines stand out in a crowd.
scotc
04-04-2006 20:54:55
 Re: Sounds of farming in reply to Charlie M, 04-02-2006 17:18:16
1066, modified turbo, planed heads, running a straight pipe, turning enough hp that we'd slip the pto clutches running the chopper. start out in hi 3/lo, snag 4th, and time hi t/a just right she sounded real nice. The 1566 wasn't far behind but being slower didn't seem quite the same. That was turned up 3 times and would out-pto the 3788 (wish i had dyno info on it) but for extended intervals I preferred our 756 that had a little file work done on the throttle stops. She smoked like a good engine should. As for sounds I could do without, the turbo whine on our cih 4240 was unbearable, and accounts for the majority of the ringing in my ears.
LumbrJakMan
04-03-2006 15:19:39
Well its got to be the sound of an Oliver 99's Detroit Screaming across the fields dragging earth with it !!
Janicholson
04-03-2006 13:45:49
 Re: Sounds of farming (unpleasant) in reply to Charlie M, 04-02-2006 17:18:16
The deafening roar of an open platform SP125 combine the necessity to be tuned to the total audio scheme so that failures (squeeks, rattles, pounding, or little hissing noises) can be detected within the roar. These things took 2 hours to grease, oil, and prep. (just long enough for the dew to burn off)
JimN
Farmallkid From Ont,
04-03-2006 11:33:15
I like my M pullin the water wagon up the hill. And the sound of the combine in the field hummin away!
mwkellner
04-03-2006 10:52:17
The whinning of the gears on farmall SC from when I was young and would ride in my grandpas lap and get to steer. My Dad still has it and it sounds the same today although now it just mows occasionally.
Janicholson
04-03-2006 10:18:30
Two Ms plowing in the same field hearing the exhaust note harmonics, dampning and amplifing the sound as they gain or loose on each other as the soil changes.
rrrRRRRrrr rrrRRRRrrr gives me goosebumps.
JimN
john d
04-03-2006 11:54:02
 Re: Sounds of farming in reply to Janicholson, 04-03-2006 10:18:30
ABSOLUTELY! My dad and I used to work with a Farmall M and a SM in the same field. The combination of harmonics and a slight doppler effect as they passed each other would give me goosebumps also!
Another great sound was that of a Farmall M and a 2-row mounted cornpicker.
My favorite combine sound was a neighbor's early '70s vintage 510 Massey with a Chevy (?) V8 in it.
rumplestiltskin
04-03-2006 08:19:08
I always liked the sound of my uncle's WD45 when he pushed it up to full throttle for the ride up the lane to the house for dinner. Must have had something to do with my grandma's cooking.
Mark W.
Dave H (MI)
04-03-2006 07:14:54
Our MTA has a nice deep throaty roar when it is warmed up and up to speed. Combined with the sound of our square baler it is music to my ears.
Jaybird2
04-03-2006 06:56:53
The deep monotone tenor of our 656 comined with the rhythmic beat of the baler is one of my favorites. I liked the sound from the wagon end of the deal because the hay bales would deaden the sound somewhat and you could almost fall asleep if it weren't for the fact that you were humping 80 lb bales in 90 degree heat.
VernMN
04-03-2006 03:34:27
The newer 6s have a nice throaty sound, but going back when I was a kid, my dad's M on the threshing machine was music as it had the rymthic sound as the pitchers unloaded the bundles.
ejr-IA.
04-02-2006 20:57:46
The sound of my 1206 with a 21'480 disk in low 4 direct and the sound of the Solar turbo talking to you.
55 50
04-02-2006 20:40:48
A 6 cylinder Case 930 under full load. Also a Minneapolis Moline "U" on belt work.
ELDON IN ONT
04-02-2006 19:33:14
WE HAD A 560 GASER THAT SOUNDED REAL GOOD PULLING A 4 FURROW 14IN. BOTTOM TRAIL PLOW.
THAT TRACTOR SOLD AT MY BROTHERS FARM AUCTION FOR $1650.00 CANADIAN (BUCK 3 80 AMERICAN). LOL
ENGINE WAS EXELLENT,RUBBER WAS 80% ONE SMALL DENT IN FENDER.STEERING WAS TIGHT; PAINT WASN'T VERY GOOD,NO POWER STEERING AND WAS A WESTERN BUILD. TO ADD INSULT TO THE WHOLE THING THE BUYER SOLD THE BELT PULLEY WHICH HAD BEEN STORED INSIDE AND IN EX. CONDITION FOR..... .. $400.00 AT THE SALE. SURE LOVED THE SOUND OF HER WORKING...ELDON IN ONT.
Shaggy
04-02-2006 19:09:01
When I was growing up I used to love to fall asleep to the guy"s out picking and also the sound of the dryer fans screaming around the area. Now all I hear is the trucks and the jake brakes as they drive down a 2 block strech to the glass plant. Iknow I messed up moving into town.
scotc
04-04-2006 21:01:13
 Re: Sounds of farming in reply to Shaggy, 04-02-2006 19:09:01
if that's the automotive glass plant on a major U.S. highway that I think you're talking about you didn't move to a very big town. Try someplace like dayton OH. it was bad enough that i made the 326 mile trek home for at least half the weekends for the better part of a year.
Dave from MN
04-02-2006 19:08:10
spring calves learning they they have what it takes to make noise and a JD 730 deisel pulling 4-16's out back in the neighbors far feild.
jeffalex2
04-02-2006 18:45:17
I like standing up on my super M as it pulls 3 rolled bales on the wagon up out of the river valley...just barkin thru the hills
Nebraska Cowman
04-02-2006 17:46:34
"The bawlin' of cattle is music, not rattle, to the men who work on the range....
the tractor vet
04-02-2006 17:29:21
Ya want to hear the sounds of farmen well son just as soon as this next weather pattern clears just come on down and bring your work clothes and boots and gloves will put you on your choise of red or greene iron as we have a wide selection of size and color and there is nothing that is realy new iron as we are still farmen with what most are maken trailer qeens . Now do you want to pull a two bottom thru 4 bottom trailer plow or do you want to go big time and go with the 5 bottom semi mount
Butch WI
04-02-2006 17:28:19
Love the sound of the Super H pulling a full gravity box of cob corn up the hill from the river valley with the sound echoing from the sorrounding treelines.
Butch
MNredfarmer
04-02-2006 17:27:38
I like the distictive sound of my 826. A very close second is our Stieger st270 with a 3306 CAT with a staight pipe.
JStratton
04-02-2006 18:47:08
 Re: Sounds of farming in reply to MNredfarmer, 04-02-2006 17:27:38
I won't forget the sound of starting up a hill in 5th with my M.
