560 exsaust manifold
Bruce Severson
04-03-2006 03:42:07
I have a 560 gas tractor that I need to replace the exsaust manifold in. The bolts/studs apear to be rusty. I am worried about breaking them off. One is already broke off where the hole in the manifold is. Dose anyone have any pointers they can offer to remove them without breaking them and how to replace the one that is broke? I would apreciate any help.
Bruce
the tractor vet
04-03-2006 09:47:49
 Re: 560 exsaust manifold in reply to Bruce Severson, 04-03-2006 03:42:07
When replacing and exhaust manifold the easiest way is to grind the exhaust manifold around the long bolts that hold it to the intake since the exhaust is junk already that way you have something to grab with a set of vice grips or 410 channel locks , and it makes it easier this way to do it then just heat around the out side on the intake and work the bolts out , while you have it apart now is the time to check the heat riser butter fly and to clean all the carbon and lead deposits out around the intake this helps with the carb iceing and faster warm up and cold stumbel. when you put the new manifold on do not tighten it down till you have it bolted up to the head then that is when you tighten the top four bolts this helps align then together .
Brownie 45
04-03-2006 05:48:16
Most of the problem in exhaust manifolds involves rust between bolt heads, lockwashers, & the manifold.If you have access to a torch[or brazing carbons], try heating the bolt heads to break the rust, using common sense on the amount of heat. When this fails, try to weld a nut on the bolt head & let the weld cool. Try backing the bolt/ stud out. Option #3 involves grinding/ removing the bolt heads, pulling the manifold off, & working at the remains of the bolts with no manifold to hinder you. Good luck.
Fredd
04-03-2006 04:41:44
I have recently purchased a 560 that has a exhaust manifold crack in the square part. I recently discovered one whole flange is cracked where it bolts on in the front of the motor. Can I braze this or do I need to hunt for another manifold? Where could I find another manifold.
thanks
Janicholson
04-03-2006 10:27:16
 Re: 560 exsaust manifold in reply to Fredd, 04-03-2006 04:41:44
The best is replacement.
Brazing will heat and oxidize off (not good)
Ni rod might work if preped and welded while attached to a head (difficult to do correctly)
JimN
