Tire Rim
Andycap
04-03-2006 08:02:35
I have a 300 Farmall with a cracked front tire rim 16" .
Only thing I can find to replace it will cost me $125.00 . Is this what I should expect to pay ?
I'm not restoring the tractor , I use it around my 10 acres . Thanks for any help . Carl
Nat 2
04-03-2006 11:50:07
 Re: Tire Rim in reply to Andycap, 04-03-2006 08:02:35
You just ain't lookin'... Look for a tractor salvage yard in your area. You should be able to find a used rim, no problem.
Andrew Z
04-03-2006 10:32:37
Try Mike, At Steel Wheel Ranch I got one for there for my Super H.
Colorado Curt
04-03-2006 09:50:04
That seems a little steep! I have some rims laying around. What is the width? Is it a 6-bolt or is the three loop type?
Dellbertt
04-03-2006 09:15:32
There has to be a welding shop near you that can fix that up for about $10-$20. If not, look for an implement salvage yard. Measure the center hole and the lug holes and they can match it.
Be creative.
Andycap
04-03-2006 09:09:15
I forgot to mention that the rim is quite rusty and thin . I have alot of doubt it can be fixed .
biggerred
04-03-2006 08:09:51
Take the tire off and weld it up, or have it done. If this tractor is a work machine, it wont mind.
