adjusting the governor
cracker
04-03-2006 18:30:16
how do you adjust the governor on a cub
Nat 2
04-04-2006 06:02:21
 Re: adjusting the governor in reply to cracker, 04-03-2006 18:30:16
I am pretty sure that there is no adjustment, nothing you can tweak with a screwdriver from the outside at least.
What is the problem you're having that you think you can adjust out? Most governor problems are caused by weak/broken springs and worn/broken linkages inside the governor.
