H M trans. gears
brian in nc
04-03-2006 23:03:07
Are the gears in an H & M the same as far as interchanging them? I need 4/5 for an H.
John M
04-04-2006 13:46:34
 Re: H M trans. gears in reply to brian in nc, 04-03-2006 23:03:07
Ive got one Ill let you have if you come get it.Where in NC are you?
Dr.EVIL
04-04-2006 08:24:03
I would guess that less than 5 percent of the parts interchange between an H and M overall. And I'd guess maybe at most 10-12 parts total interchange in the transmissions & rearends. The brake shaft seals, maybe a couple special bolts.... but gears & shafts in M's are MUCH bigger than the same ones in H's. Up until the very late 40's an M was considered "Too Big" for most midwestern farms.
tn terry t
04-04-2006 03:34:59
i dont think they are the same but the gears are still available from this site and numerous others if you want used you might try steel wheel ranch or other salvage yards
