farmall H rear rims
combinekid
04-04-2006 21:53:24
I have a mismatched set of tires and rims on my H the left tire is a 11-38 (12.4-38) and the right tire is a 10-38. The left rim looks like it has about 3 stairsteps in it. The right rim has a ledge then about a 45 degree chamfer. If I understand right the stair steped rim should be a 11" rim and the chamfered rim should be a 10" rim. Am I correct on this. I want to match the larger of the two so that at least the tractor will sit level and drive strait. thanks a bunch for the help
Andrew Betzner
04-05-2006 15:23:27
 Re: farmall H rear rims in reply to combinekid, 04-04-2006 21:53:24
the kind your talking about with the steps is called a W drive rim. They are about 180-200 a pop. The other kind is a drop center. I have a 9x38 drop center rim for $80 if you live in northern indiana.
Keith-OR
04-05-2006 11:07:35
 Kid is in SE WA. in reply to combinekid, 04-04-2006 21:53:24
Would be expensive Shipping... any of you driving this way soon???.:>) :>)
Keith & Shawn
jhb
04-05-2006 08:09:13
I have 2 rims with mounted 13.6X38 tires. Located
in Eastern Iowa. Send me your phone number and
I will call you. The tires I had mounted. Good tubes, solid tires, good rims. Drop center rims
will fit JD or Farmall. Reasonable price if we are
close, same area.
GordoSD
04-05-2006 06:39:39
Have rims here in SD.
Keith-OR
04-04-2006 22:16:10
Ck, Andy help you out for rims for your H??
Keith & Shawn
JiminIA
04-05-2006 05:13:04
 Re: farmall H rear rims in reply to Keith-OR, 04-04-2006 22:16:10
Ck, Where are you located? I have several H rims, let me kinow if I can help. I am in SEIA. Thanks, Jim
combinekid
04-05-2006 23:00:36
 to keith in reply to JiminIA, 04-05-2006 05:13:04
Keith I called Andys number and left a message for him to call me, but have not heard from him. I've been pretty busy these last few days getting irrigaton water going but plan to call him again here shortly. I was just curious about the rims as I want to make sure I get the right thing.
