Starter ring gear for W9
daballmakes
04-05-2006 05:59:41
I am looking for a ring gear for a W9 either a good used one or a new one. I have also been told that I could possibly just take the flywheel off and rotate it or rotate the ring gear. Is this possible?
Thanks,
Derrick
OK PSU Kid
04-05-2006 11:14:43
 Re: Starter ring gear for W9 in reply to daballmakes, 04-05-2006 05:59:41
Wish I could help, my W9 starts so easy with the crank I never use the starter. good luck
OPSU Kid
Joe Dowling
04-05-2006 06:39:08
Replacing the ring gear is easy once you have the flywheel off the engine. If you have an oxyacetylene torch and are good with it, you can do it yourself. If one of the above does not apply, take it somewhere that knows how to replace it. Basically, you remove the old one by cutting it with the torch. THe new one is expanded gently with heat, (heat treating oven is best, but the torch works too), and setting it inplace on the flywheel until it cools, and shrinks to lock it in place. I would never bother with trying to turn an old ring gear. Not worth the hassle.
Bob M
04-05-2006 06:15:32
Derrick - Give Carter & Gruenenwald a call (punch below...) They should be able to send you with a new ring gear at a reasonable cost.
Often you can remove a worn ring gear, turn it around and rotate it 1/4 turn, then put it back to get more service out of it. However you still gotta go thru all the work of of splitting the tractor to do it. And for around $50 you can install a brand new ring gear - it'll be $$$ well spent. (Also install new clutch disk, pilot and throwout bearings while you have the tractor split - it will never be easier.)
Another tip: Replace the starter drive (bendix) when you replace the ring gear!
