1066 3-Point Extension Arms
Wicksfield
04-05-2006 09:25:04
The extension arms on my 3-point hitch will not slide out of the lower hitch arms.
What is a good way to free them up?
Wicksfield
04-05-2006 12:47:55
 Re: 1066 3-Point Extension Arms in reply to Wicksfield, 04-05-2006 09:25:04
Thanks guys for the advice. I've tried pulling them out by hooking up to a rail road iron corner post. I broke the post off and thought that's enough of that crap.
I've soaked them in Blaster from time to time. I'll try the saw blade idea. I hate to use heat as afraid to take the temper out of the arms plus makes things ugly.
Allan In NE
04-05-2006 10:53:31
Wick,
Took me three days to loosen 'em up on one of my tractors. I cleaned, soaked, beat 'em with a hammer and everything else.
Finally, I hooked to to the drawbar of another tractor that had the brakes set/locked and "yanked" on 'em with a "jering" action.
Popped 'em loose.
Allan
the tractor vet
04-05-2006 09:32:07
Well soaking them with a good penatrating oil or diesel and a blow gun to get all the dirt and rust out a littel lite BMFH a old hacksaw blade to get up along side of the links to dig the dirt out with . They can be real fun to get out i have seen them stuck so bad that after pullen a plow for a week they never move .
Duner Wi
04-05-2006 11:39:58
 Re: 1066 3-Point Extension Arms in reply to the tractor vet, 04-05-2006 09:32:07
Why are they removable? Thanks.
the tractor vet
04-05-2006 12:26:06
 Re: 1066 3-Point Extension Arms in reply to Duner Wi, 04-05-2006 11:39:58
Well they were designed so that they could be pulled out about 4-5 inches for ease of hooking up to larger implements as you sure as heck are not going to move a large plow or culivator by hand and also so that you could change end from cat II to Cat III balls .
Duner Wi
04-05-2006 19:36:03
 Re: 1066 3-Point Extension Arms in reply to the tractor vet, 04-05-2006 12:26:06
AAhh. That makes perfectly good sense.
