IH 444 loader capacity
wkw
04-05-2006 13:34:22
Can anyone tell me roughly what the weight capacity of a loader on a IH 444 is?
Thanks in advance
Ken
Alberta
FromJB2
04-06-2006 17:26:32
 Re: IH 444 loader capacity in reply to wkw, 04-05-2006 13:34:22
Hi Ken in Alberta, to muck out a horse barn easily, make sure the 444 has power steering and hydraulic dump on the bucket and the bucket has tines on it. There were two types of buckets, one type was called a gravel bucket and this is similar to what you see on a industrial front end loader like a CAT loader. The other was an agricultural bucket with tines on it like a fork with an optional "dirt plate" that could be installed over the tines to make it somewhat of industrial type bucket. The problem with this "dirt plate" was that if the tines become slightly bent or twisted is was almost impossible to install or remove the "dirt plate". If your horse manure has lots of straw in it then you will require the bucket with the tines or the manure straw mixture will just roll in front of the bucket. Hope it is an IH 1501 or 1550 loader with hydraulic controls mounted on right side of loader frame. If it is 2250 loader this loader is to heavy for 444, require 584, 684 size tractor. If the rear tires are not loaded with calcium/chloride solution then put some weight on the rear 3pt hitch. Neighbour had made a big cement block for his with a steel rod through it that he just put onto the 3pt hitch when he was doing loader work.
Re seat, I have seen replacement seats at TSC. We replaced a seat on the B414 (older model) that we had and all we had to do was frabricate two mounting brackets as the seat is only attach at two places on the casting of the hydraulic reservior.
Enjoy
JB2
FromJB2
04-05-2006 16:51:43
Hi wkw, we had an IH 1501 on a 434 and an IH 1550 on a 384 and both loaders would lift so much as the rear wheels would almost come off the ground and the tires were loaded with calcium/chloride. Would lift large round bales but would require additional weight on the 3pt to have traction to move in mud or snow.
JB2
wkw
04-05-2006 21:20:17
 Re: IH 444 loader capacity in reply to FromJB2, 04-05-2006 16:51:43
Thanks JB2. I am looking at purchasing a 444 this Friday. I have never owned a tractor before . It is getting a little too much mucking our horse barn by hand and using my quad in the role of tractor. The only problem with the one I am looking at is the seat is destroyed. Are these seats kind of standard? Can I find "generic" replacement seats?
Thanks again
Ken
