pto problem with B275
Dave in Va.
04-05-2006 13:44:32
Hey guys help me decide ,will the sliding gear clutch come out the back with the pto shaft? Thisis after puling enguagement lever from side of transmission. Thanks in advance Dave in Va.
dave in va
04-05-2006 20:10:38
 Re: pto problem with B275 in reply to Dave in Va., 04-05-2006 13:44:32
THANKS Parts man I,ll give it a try, will pull it out of the old parts tractor first to see how it goes. Thanks again for the help Dave
parts man
04-05-2006 15:39:08
Dave, The best bet is to leave the lever in place and use it to push the shaft and sliding gear out the back. The one hitch in the process is a lock ring in the hole that will catch the slider and drop just inside at the back, but you will be able to reach it with a magnet or the like.
