MD Bosch Inj. pump ? Tractor Vet, others
Andy in Ohio
04-05-2006 17:35:43
When looking into the oil fill hole on the early Bosch pump I see diesel fuel flowing inside and not oil. On a post last week Tractor Vet mentioned a primary pump shaft seal. IN the parts manual it only mentions 1 seal and that is the end plate oil seal where the pump hooks to the engine. Is this it or where do I look on the pump to find this seal? It mentions nothing about the primary pump shaft? Thanks for ANY help or suggestions! Andy
the tractor vet
04-05-2006 19:03:26
 Re: MD Bosch Inj. pump ? Tractor Vet, others in reply to Andy in Ohio, 04-05-2006 17:35:43
You got a picture of your pump as i have only seen the I H pump now i have heard of and other but never seen it , I have been around a bunch of the older I H diesels since the 60's but that does not mean that i have seen it all.
the tractor vet
04-05-2006 19:03:25
Andy in Ohio
04-05-2006 20:24:02
 Re: MD Bosch Inj. pump ? Tractor Vet, others in reply to the tractor vet, 04-05-2006 19:03:25
I am using the international parts catalog for fuel injection pumps no. PU-27A. It has both the IH and the Bosch. The IH pump diagram shows a primary pump and shaft, but no seal on that shaft. THe Bosch diagram shows a governor unit where the IH unit shows the primary pump? I will try to upload a picture tomorrow. Where is the shaft seal on the IH pump, maybe that will give me an idea where this one is, dunno? Andy
