1066 MCV telltail light - finally checked
Michael Sheik
04-07-2006 04:40:29
Hey tractor vet. Well, not a lot of new news on this light but I did finally get a chance to crawl in there last night and fire her up to see if it would work. I do not think it is so I proceeded to try to get the little red lens off, wouldn't unscrew, so tried to unscrew chrome ring behind lens, it turned and after a little ways pulled out. Here is where I realized that inexperience shows up. After got lens and chrome ring pulled out I realized it didn't unscrew to start with. It just turns like a bulb a little ways and pulls out. That is not the half of it. Now the back half of the bulb housing is behind the opening and got to figure out what bolts/ plate to pull to get at it to put back together. Clue me in please.
THE TRACTOR VET
04-07-2006 06:23:25
 Re: 1066 MCV telltail light - finally checked in reply to Michael Sheik, 04-07-2006 04:40:29
Remove the bolts holding that panel that the lite is in and pull it back just a bit and ya can get wright in there don't try going down thru the top .
chadd
04-07-2006 05:15:25
Don't feel stupid about the MCV bulb. It must have taken me 20 minutes staring at it scratching my head before I figured out how to get it apart. Part of it was just sheer luck, and not skill. I ran into the same problem as you, the back fell behind the dashboard. What I did is I removed the cover over the 3 auxilliary gauges. Only problem is my arm was too thick to get through the mess of wires and down where it belongs. If your arms are skinnier, try that. If not, you can do what I did. I removed the bolts from the black panel that the light is mounted into. Once they are all removed,CAREFULLY pull the bottom of the panel out from the dashboard just enough to get your hand in. You need to remember that the oil pressure gauge and coolant guage are both mounted on the top. If you pull too hard, you risk kinking the small tubing running to them. Now put the new bulb in. Now before you put it back on, there should be a spring that sits between the dash plate and the back of the light housing. If not, it fell off when it fell behind the dash. What you need to do is to push the back of the light housing against the dash plate to compress it as much as possible while simultaneously pushing the plastic lens half into the back half and once it has bottomed out against the plate, turning it clockwise(I think). If you have one person to push in the housing and another to push in the lens and turn, it makes it a lot easier, because the spring is hard to compress alone I had the front half come flying out several times. Then put in the ignition key and turn it to the run position. If it works put the bolts back in the plate and you should be set. If not, check to see if the wiring is damaged or if there is corrosion in the base or the switch if faulty down at the MCV. Hope this helps.
