B434
Jack Backus
04-07-2006 11:14:27
Just re-did complete engine. I need to know clutch setting if anyone has them.
Thanks in advance for any help.
FromJB2
04-08-2006 08:27:19
 Re: B434 in reply to Jack Backus, 04-07-2006 11:14:27
Hi Jack, I have Operator's Manual for B414 witch is the older model. The book only describes how to set the clutch pedal adjustments and not how to adjust the dual stage clutch internally.
Here is clutch pedal adjustment:
1)7 inches of free travel from floor board to rest position. Adjust by adjusting bolt on clutch arm.
2)1/2 inch free travel. Adjust by loosening bolts on clutch arm at clutch release shaft and rotating clutch release shaft.
I belive if you search the archives for B414,434 or 444, someone posted the procedure to adjust the dual stage clutch through the inspect plate under the bell howsing.
Good luck
JB2
