what plow should I get.
Andrew Z
04-07-2006 12:06:21
I have been looking at getting a plow to make the garden alittle bigger this year. In my area There is a JD 2 bottom trailer plow and a fast hitch 2 bottom plow for a Super C. I have a Super C with a fast hitch. I"m just looking to plow a garden (never been plowed sod now) and go to a plow day. The fast hich plow is missing the "cultors" is that important to have the JD plow is complete. What would be the better choice? Thanks Andrew
Marv
04-07-2006 14:34:02
 Re: what plow should I get. in reply to Andrew Z , 04-07-2006 12:06:21
Buy the trailing plow. Then tell me where the mounted plow is located. I,ve been looking for one of those.
El Toro
04-07-2006 12:59:51
I would agree with Matt using the fasthitch plow.
When I had a Super C I could just back up to the plow and it was installed. I didn't get off the tractor. I did blow one of the hydraulic lines
when I had just finished the last furrow and lifted the plow. I made up 2 new hoses and replaced both of them. Hal
Farmall 43
04-07-2006 12:15:40
If I were you I would grab up that fast hitch plow in a heart beat. It definitly makes it easier to plow than with a trailer plow. It also alowas you to square off your field better. I love my fast hitch plows. I have 3. One for each tractor I plow with. 314 for the 340 and 450 and a 414 for the 400D. As for coulters I personally do not use them. If you really must have them they are readilly availible at most tractor junk yards. A few people will argue that you must have them, But even in sod I disagree. Disk it once over then plow and then disk again. This will give you a much better seed bed. Good luck and enjoy. Matt
Andrew Z
04-07-2006 13:23:47
 Re: what plow should I get. in reply to Farmall 43, 04-07-2006 12:15:40
Thanks guys for the replys, I have never used a Fast Hich plow they seem really easy to use, are they? thanks Andrew
RN
04-07-2006 18:05:21
 Re: what plow should I get. in reply to Andrew Z , 04-07-2006 13:23:47
Fast hitch easy? Fairly easy, get a manual to adjust depth wheel, watch angele adjust on fast hitch for 1st share if you have it on plow. Used a 3bottom on 350D to do garden couple years back- handy to just lift, backup and do another furrow. RN
