Dating my H
Kyle Bosch
04-07-2006 13:47:51
I have recently acquired a farmall H from my late grandfather and wanted to do a restoration project on it. my problem is the data plate is not on the tractor for some reason,and i was wondering if anyone knew a quick way to determine the year of this tractor or how i would even go about determining what engine rebuild kit i would need from yesterday's tractors. apparently the S/N determines the engine kit i need.
Paul G. in Mn
04-08-2006 18:50:25
 Re: Dating my H in reply to Kyle Bosch, 04-07-2006 13:47:51
Anther Place to check would be if it might happen to be an early 1939 would be the topside of the frame rail under the generator. I acquired a M from my grandfather after he passed and it never had a tag. Come to find out it was an early 1939 and some of those never had tags from the factory. Paul
Try Dating a Girl Instead
04-08-2006 08:02:05
Try dating a girl instead my friend-much more rewarding. You are taking this tractor thing way too seriously.
NDS
04-07-2006 16:27:44
Another way to get approximate (within year or so) age of tractor is with casting codes. Go to archives at top of page choose keyword search and search for casting codes in Farmall forum. You will find more information on casting codes than you will want to read.
RustyFarmall
04-07-2006 13:54:24
Look on the engine block, in the area where the generator is located, you will find a small flat area. The engine serial number will be stamped there.
satsop
04-07-2006 13:52:31
Kyle the sereil number is also on the block on a smooth area on right front by the generator.
Jim
Harley
04-07-2006 17:11:13
 Re: Dating my H in reply to satsop, 04-07-2006 13:52:31
Kyle, you had me worried there for a minute. I talk to my tractors but I have never really "dated" one. Then I figured out what you were asking. My mistake. Harley
mulligan
04-08-2006 03:48:07
 Re: Dating my H in reply to Harley, 04-07-2006 17:11:13
Yep, I kind of expected to see this one on Jerry Springer from the message header.
David Kronwall
04-08-2006 03:00:24
Harley, I'm with you. I had the same first impression. Now, I have to admit, I may have given my Super M a gentle pat now and then, but we have YET to go to a movie. ;-}
David
