H tranny siezed from sitting for years?
arod
04-07-2006 15:41:50
cannot release tractor from 3rd gear, do not know how long it has sat. will pull the top cover, then what?
old
04-07-2006 17:58:14
 Re: H tranny siezed from sitting for years? in reply to arod, 04-07-2006 15:41:50
I have had that problem on 2 tractors I've been working on. After getting them to run they slowly got to where I can now shift them like they should. Don't know if you could do this but heres and idea for you. Jack it up, start the engine and let it run and spin the wheels for a while. The tranny may get the where you can shift it after doing that. If its locked up from sitting that is and not locked in 2 gears.
Andy Martin
04-07-2006 15:55:01
First pull the shifter lever out and see if you can shift it into neutral with a long screw driver.
