Oil refill plug ID
Nelsen
04-08-2006 07:06:26
Have a Farmall C. Not sure where oil add site is on tractor for crankcase. How is oil check done? CAn I use Mobil-One? I'd like to use Mobil-1 and Rislone (1qt). How much oil does the crankcase hold? Next is to change the oil in the rear-end. What kind of fluid? I'm a real novice, but love my old tractor. It's been setting in the barn. I start it occasionally to let it run 10 min.
CNKS
04-08-2006 17:36:54
 Re: Oil refill plug ID in reply to Nelsen, 04-08-2006 07:06:26
Use a brand name 30W or 15W-40 in the engine. Forget the Mobil 1, it is total overkill for that tractor. You don't need the Rislone either--all it does is make money for the manufacturer, modern oils have all the additives they need.
TDK
04-08-2006 09:41:24
Remove the small breather cap that sticks through center hood. There's two check valves on the oil pan. Fill til it starts to run from the top valve. Crankcase holds 5 qts. Use 85W-90 gear oil in trans/differental. The types of oil to use is countless, if it is not a new rebuild, I usually use a good brand of 30W.
