Farmall C losing engine power
dave in york ha
04-08-2006 10:49:33
I need help. I've been running a nice 1948 Farmall Cub. Last year, just before winter, the tractor started sputtering around and losing power. I checked the float bowl and there was no blockages. Someone at work said it could be something to do with a bad carbureator float nipple. If I tap the bottom of the carb gently with a hammer, it acts like it's getting more gas for awhile, then starts sputtering around again. To you experts out there, does this sound like spark plug replacements, or something in the carb (like the float or the nipple)? Thanks in advance for all of your help! I'm trying to get it working before the grass gets too high again!
Dave
River Bottom Farmer
04-08-2006 11:06:11
 Re: Farmall C losing engine power in reply to dave in york haven pa, 04-08-2006 10:49:33
If tapping the carb lightly seems to improve the way it runs I would pull the carb and rebuild it.The kits are available at Napa or TSC for around thirty to forty dollars and a good tune up couldn't hurt either.But the carb should do the trick from what your sying sounds like the needle is hanging up in the seat..... Hope this help...River Bottom Farmer
