super C filter housing
R Fink
04-08-2006 18:29:10
what seals the filter canister to the housing, is it metal to metal or is there a square packing that sits iiin the groove?
old
04-08-2006 19:33:59
 Re: super C filter housing in reply to R Fink, 04-08-2006 18:29:10
Also when you pull out the old one be sure to clean the groove up real good becuase if you leave any of the old seal or dirt in there it will leak.
Bob
04-08-2006 18:31:32
There's a square packing down in the groove. If you are having trouble with the filter cannister leaking, likely there is already a HARD seal ring jammed down there!
Peabody
04-08-2006 18:52:23
 Re: super C filter housing in reply to Bob, 04-08-2006 18:31:32
Ditto. Been there, done that. Take a pocket knife or small screwdriver and probe into the groove for a possible "hiding" sealing ring. Easy to miss if dirty oil is covering it.
