1936 F-20 paint
Jerry Telker
04-08-2006 18:52:09
I'm in the process of restoring a F-20 and would like any info as to the paint. Were they battleship gray or red ? I could use any help that anyone has. Thank you in advance!!
F-Dean
04-09-2006 08:00:53
 Re: 1936 F-20 paint in reply to Jerry Telker, 04-08-2006 18:52:09
According to an article in Red Power a few years ago, the first Red F-20 was number FA-68749. All before it were McCormick Gray (Van Sickle makes a good version) and all after it were red. Regardless of the serial number, all F-20 wheels and draw bars were red.
K-Mo
04-09-2006 05:11:41
The following link will take you to the info you want. Tractors produced after Nov 1, 1936 were to be red.
http://www.wisconsinhistory.org/libraryarchives/ihc/paint/display.asp?pageurl=100_01.gif
Nebraska Cowman
04-09-2006 03:33:34
It was a very dark gray, almost black. In fact I match mine by adding a little white to Rustoleum gloss black. I believe the early Regulars before about 1928 were a lighter gray but there were no color photographs then and all the old guys are dead.
CNKS
04-08-2006 19:58:34
I believe IH changed to Harvester Red, now known as IH 50 in Oct or Nov of 1936 -- so you can go either way, unless you can find the actual month of production. And, there were two shades of gray -- someone else can comment on that.
James Williams
04-08-2006 19:47:30
Yours should be gray,red wheels,and I think red drawbar,Check with Fordson house I beleive they sell Farmall Gray.If you can find some gray on your tractor you might be able to match it
