engine kit for 400 diesel?
Nebraska Kirk
04-08-2006 20:16:22
Are there engine rebuild kits available for the Farmall 400 diesel?
Jim J
04-09-2006 14:02:38
 Re: engine kit for 400 diesel? in reply to Nebraska Kirk, 04-08-2006 20:16:22
Last I ones I ordered STD and .030 mains were available. And I could get rod bearings in Std, .010, .020, & .030. If you want me to I can check for you.
John M
04-09-2006 06:54:50
I sold a SMD a few years back because I thought the bearings werent available.The guy I sold it to said there is a guy who advetises in Red Power that was selling them.
Dave Slater
04-09-2006 12:19:54
 Re: engine kit for 400 diesel? in reply to John M, 04-09-2006 06:54:50
Check with 618-783-4102
the tractor vet
04-09-2006 07:42:32
There are a FEW NOS bearing left but not in all sizes and hope ya got a BIG check book but here again best have the crank checked as i have seen to many of them with the thrust wore out and if they are wore beyond spec. I will not use it . Ya got to remember that that seires engine has been out of production since 1958 and most of them were used to much when they were new . And i was told once when they stopped maken parts for thembut i forget on the date so what is left of the OEM is all that is left. None of my engine books list anything for a MD -450D W9D thru TD24 so yea those old tractors and dozers bring big bucks because they are old and people want to rebuild fix up restore but keep in mind that the parts are hard to find and getting harder every day to find and the price keeps going up along with tryen to find good blocks cranks and heads .
El Toro
04-09-2006 04:00:35
Check with aicatalog.com for a kit. Their number is 888-289-4020. You can try Clevite at 877-808-
0698. Hal
the tractor vet
04-09-2006 06:35:59
 Re: engine kit for 400 diesel? in reply to El Toro, 04-09-2006 04:00:35
Not listed in Clevitt DEAD PUPPY along with all the rest and have been for many years.
the tractor vet
04-08-2006 20:39:17
There are sleeve and piston kits from Case I H still left but the problem ya run into is finding the bearings as they don't make them any more and the other thing is CHECK YOUR CRANK as the thrust ware bad on them and they never did make and over sized thrust bearing and if the crank is moving back and forth tomuch it will cause BIG problems on a fresh engine BTDT .
