Tractor Model Numbers
Tim in WI
04-08-2006 20:30:06
Can someone explain the 1960's tractor model numbers? Is there some kind of code? Does 504 mean anything? Was it fifth in a series? Does part of the number tell the tractors horsepower? Do the numbers go in sequence? Or am I assuming to much? Thanks for any help, I am new to 1960's International/Farmall tractors. Tim
Tim in WI
04-09-2006 18:54:11
 Re: Tractor Model Numbers in reply to Tim in WI, 04-08-2006 20:30:06
Thanks guys!
sammy the RED
04-09-2006 06:09:27
Neb. Tractor Test:
240= 32.22 horsepower 340= 36.12 horsepower 460= 51.63 horsepower 560= 65.25 horsepower 660= 81.81 horsepower 404= 36.70 horsepower 504= 46.20 horsepower 606= 53.80 horsepower 706= 76.56 horsepower 806= 93.27 horsepower 1206= 112.64 horsepower
Allan In NE
04-09-2006 06:54:38
 Re: Tractor Model Numbers in reply to sammy the RED, 04-09-2006 06:09:27
Hey Sammy,
Ya need to give me an "atta boy". I was really "bitin' my tongue" on that one. :>)
Allan
Dave H (MI)
04-09-2006 16:28:15
 Re: Tractor Model Numbers in reply to Allan In NE, 04-09-2006 06:54:38
I'll do it for him, we're almost neighbors.
Atta boy, Allan!
JJK
04-08-2006 21:52:02
The model numbers from the hundred series to the 88 series pretty much just gives you a time frame of the tractors once your familiar with the line up and in most cases if its an International utility or a Farmall row crop. The last two digits always gives you the series, such as the 06, 56, 66, 86, 88 series tells that these are the big dog Farmall row crop tractors and the 04, 44, 54, 64, 84 series states these as the Inernational utility tractors. Now the numbers in front of the series # gives you an idea the size of the tractor but doesn't tell you the hp. Once you know the range of hp in a series you can get an idea about what one particular tractor might be. For example the 50, 52, and 5488 hp range is about 135 for the 5088, 154 for the 5288, and 181 for the 5488. To make it more cornfusing for ya, in the 88 series there is the 30 series (odds and evens make a difference) and the 50 series. First the odd 30's, the 33, 35, and 3788 were the 2+2 tractors. The even 30's were 30, 32, 34, and I think a 3688. These were the smaller row crop tractors with basically the same transmission and rear end as the 06 series. The 50 series stated above in hp difference was a bigger tractor with a new transmission. I hope this will give you an idea how the numbers work in the IH line up and maybe somebody else can put their 2 cents in as well with more info.
earthmasterk
04-08-2006 21:33:39
240= 20 horsepower 4 cyl. engine
340= 30 horsepower 4 cyl. engine
460= 40 horsepower 6 cyl. engine
560= 50 horsepower 6 cyl. engine
660= 60 horsepower 6 cyl. engine
404= 40 horsepower 4 cyl. engine
504= 50 horsepower 4 cyl, engine
606= 60 horsepower 6 cyl. engine
706= 70 horsepower 6 cyl. engine
806= 80 horsepower 6 cyl. engine
1206= 120 horsepower 6 cyl. engine
Now, do you get the idea?
CNKS
04-09-2006 10:25:33
 Re: Tractor Model Numbers in reply to earthmasterk, 04-08-2006 21:33:39
Not quite that simple, you are close on some and way off on others.
