Belt Pulley Questions
David Kronwall
04-09-2006 03:48:45
When I bought my '53 Super M last fall at an auction, I didn't have a belt pulley. I found one advertised in the YT Classifieds that came off an M, and I bought it. Anyone have any tips for cleaning it up? The face of the pulley is a fiber-like, hard rubber-type material that seems to be coated with greasy dirt or residue that may have come from running a belt. It has a few small nicks here and there, and in places shows the seams in the material that go around the circumference of the face. The seams are tight, but they're visible. It also has red paint showing through in places, so I assume the face was painted red. I don't plan to run a belt with it, just want the pulley to look clean. The face shouldn't be painted red, should it? The metal parts, yes, but not the face. I seem to remember them starting out black when new but then going to dark grayish/brown through use. Any tips, guys? Thanks!
David
Nebraska Cowman
04-09-2006 04:41:05
 Re: Belt Pulley Questions in reply to David Kronwall, 04-09-2006 03:48:45
The pulleys are made of laminated paper. I use clear white shellac to seal them.
David Kronwall
04-10-2006 04:01:42
 Re: Belt Pulley Questions in reply to Nebraska Cowman, 04-09-2006 04:41:05
Howard,
Thanks for responding. Laminated paper, huh? You wouldn't think that would hold up to wear and tear, but obviously it does. Before coating with the shellac, how would you clean one up? Would you scrape it, brush it or what? I imagine you might want to avoid too much in the way of chemical cheaners, or you might destroy that laminated surface. Would that be right? Thanks.
David
Cue P.
04-10-2006 09:36:25
 Re: Belt Pulley Questions in reply to David Kronwall, 04-10-2006 04:01:42
All i did to clean mine was run the pully and held some med grade sand paper on a block against it lightly while it spun. Cleaned right up nice.
David Kronwall
04-11-2006 03:38:56
 Re: Belt Pulley Questions in reply to Cue P., 04-10-2006 09:36:25
Cue P. Thanks for the idea. That tells me what I need to know. David
