PTO on AV
cajunace
04-09-2006 18:57:50
Ia it OK to leave PTO running even when not using it?
Dave BN
04-09-2006 21:33:31
 Re: PTO on AV in reply to cajunace, 04-09-2006 18:57:50
You need to investigate why it's making noise. It's OK to leave it running, except for the dangger of have the shaft turning all the time, as long as your oil slinger gear is working ok. Otherwise you'll ruin the transmission bearings. Dave.
cajunace
04-09-2006 20:12:52
Well when it is not engauged it makes a little bit of noise. When engauged it makes no noise.
CNKS
04-09-2006 19:22:20
Why do you want to? It adds uneeded wear to the gears. If you are using it you should always shut it off before getting off the tractor.
