Can't find 1940 M clutch release bearing grease z
RonFromCT
04-09-2006 19:01:58
Well, I've looked and looked and looked. I've read everything anyone on this site has said on the subject, and I'm still lost. The problem is that I can't seem to find the grease zerk for the release bearing that's supposed to be in the clutch housing . There are two holes on the left of the tractor - one (the larger) immediately below the clutch pivot shaft and one (smaller) a few inches toward the rear. When looking and probing into the larger one, I can't see anything that looks like a zerk. The smaller one had cork in it, but removing that just revealed a flat steel face. To make matters more confusing, the parts manual shows the "tube" that is supposed to be for the pilot bearing as the lube point for the release bearing(!?)
Some ideas:
1. The bearing was replaced with a sealed bearing? Unlikely, but hey, I'm dyin' here.
2. The zerk backed out and fell to the bottom? There looks to be a point directly inside where there "could" be a zerk, although it's filled with grease.
3. I'm clueless, hopeless, and just plain stupid (very likely), in which case I should just run it till the clutch freezes, drop the belly pump and solve the whole puzzle at that point.
If you've already solved this problem and want to be imortalized in my household as a Tractor god, then please let me know how to find this !#$%?@#@*&# thing.
Ron
Geoff NY
04-10-2006 13:23:42
 Re: Can't find 1940 M clutch release bearing grea in reply to RonFromCT, 04-09-2006 19:01:58
From what I read I believe that you are looking for the "throw out" bearing and not the pilot bearing zerk. These are mounted on a tube, and on two of my tractors had backed out and fallen down with the dirt grease oil and mouse droppings. Pick around and find it and screw it back in and you"ll be in business.
RonFromCT
04-10-2006 19:14:48
 Re: Can't find 1940 M clutch release bearing grea in reply to Geoff NY, 04-10-2006 13:23:42
Thanks Geoff - any hints on how you found it and dug it out of that hole? Coathanger perhaps?
John M
04-10-2006 03:26:32
Mine has a little flip up type deal to cover the hole for the grease zerk.Theres a zerk with a tube that goes to the release bearing,the pilot bearing,well for the life of me I cant recall how to grease it up I think I do via the hole on the bottom of the torque tube,or maybe another one on the side or something like that,the zerk almost always lines up with a hole,thats all I can remember.the "tube" for the pilot bearing is made into the flywheel.
