Drain on battery - help
BillWv
04-10-2006 04:32:25
YTers,
I think I have a problem with my Super C.
I have the battery on charge (original 6v system). So it is charging at about 2 amps, and out of curiosity I pulled the ignition switch out. The charge went up to 4 amps. Should it do that? Or do I have a short somewhere?
Thanks for any ideas.
Bill
BillWV
04-10-2006 09:36:36
 Thanks, guys (nm) in reply to BillWv, 04-10-2006 04:32:25
old
04-10-2006 08:15:18
 Re: Drain on battery - help in reply to BillWv, 04-10-2006 04:32:25
Think about it, you turn it on and if doesn't draw more amps then you have a problem but since it does draw more amps sounds like all is well. If you do the same thing on any car or truck it will also do the same thing.
John T
04-10-2006 06:18:10
Bill, I dont think you have a short either. With the Ignition ON and assuming the points are closed as they usually are when shes setting, the coil could draw 3 amps or more out of the battery which is why the charger tries to pump more amps in.
John T
Bob M
04-10-2006 04:44:36
Bill - Not to worry....that's perfectly normal!
What's happening is when you turn on the ignition it draws a couple amps from the battery. And when the battery charger is connected it senses this, then increases the current it sends to the battery to compensate for it.
Thus the extra couple amps that shows on the charger's ammeter when the ign switch is pulled out.
