Farmall Pipe.s
kirk in ks,
04-10-2006 11:10:31
which pipes are which on early farmall,s?
I see short one,s, short,and curved one,s,long
straight one,s,and then of sourse the one,s that have no pipe that come out of the bottom of carb,
sammy the RED
04-10-2006 19:18:54
 Re: Farmall Pipe.s in reply to kirk in ks,, 04-10-2006 11:10:31
How early ?
1920's ?
jonathanbrown
04-10-2006 11:42:39
the only exception I could think of a farmall tractor exhaust not be routed as already described would be the farmall regular that was directed toward the ground and looks as though is coming out the bottom of the manifold.
Janicholson
04-10-2006 11:34:06
No offense intended, but I have no idea what you mean. Assuming you are referencing exhaust pipes, they are often customized by many owners (but) they either come out the top through a hole in the hood, or curve forward and dowm in front of then below the intake area to a muffler. Farmalls almost all are up through the hood. Later series may have exhaust pipes away from the sheet metal.
JimN
