Need hydraulic help, NH3 valve on air seeder
Steven@ND
04-10-2006 18:11:04
We want to use a hydraulic on/off valve for our anhydrous set up on our air seeder. We are out of remotes to operate it.
Would it work to tee off the lines that raise and lower the main chisel plow frame? Basically setting it up so that whenever you raise it out of the ground, it shuts off... and when you go down into the ground it comes on. Would a tee work? Or do we need some fancy valves?
Thanks for any help!
billonthefarm
04-10-2006 19:02:13
 Re: Need hydraulic help, NH3 valve on air seeder in reply to Steven@ND, 04-10-2006 18:11:04
Steven I have seen it done like that and it did work. I know they were hooked into the main raise lower lines. In any system the cylinder that needs the least pressure will move first. My recolection was that before you raised the nh3 toolbar if you bumped the lever it would shut off the flow and then wait a second and then complete the lifting. When you lowered the weight of the implement will keep the valve for the nh3 closed untill the implement was in the ground. Good luck and make sure you try it a few times before you go to the field. bill
