Pictures of 2 or 3 pt hitch on 300 Utility or comp
Matt Williams
04-10-2006 21:13:34
I am trying to figure out what I am missing and would appreciate any pictures to illustrate what should be there.
My tractor had a backhoe on it so there is nothing there right now.
I appreciate all your help.
Feel free to email if you like.
Thanks.
JAS,Tn.
04-11-2006 10:18:02
 Re: Pictures of 2 or 3 pt hitch on 300 Utility or in reply to Matt Williams, 04-10-2006 21:13:34
Look in tractor photos for 1956 IH 300 utility
There is a pic of the fasthitch hope it helps you
John
Bill46
04-11-2006 04:55:19
Nope...totally different. Look around on here and see if you find a photo. If not maybe I can take a picture this weekend.
The hyd cylinder mounts on the left side up near the seat.
PaulW_NJ
04-10-2006 21:42:11
third party image
This is the FastHitch on my 340U. I"d think it would be the same on yours.
Matt Williams
04-11-2006 13:26:21
 What do you have to do to change to a 3 point hitc in reply to PaulW_NJ, 04-10-2006 21:42:11
What do you have to do to change to a 3 point hitch?
Thanks.
jmauss
04-11-2006 19:56:58
 Re: What do you have to do to change to a 3 point in reply to Matt Williams, 04-11-2006 13:26:21
Matt, I have a 350 Utility with a fast hitch. I just converted to a 3 pt hitch so I could run a rotary cutter set up for a standard Cat 1 3 pt hitch. I could not figure out how to post the pictures in my message, so I posted 3 pictures over on the Galleries section on the left side of this page. Click on "Tractor Photos" and look for the 3 titled "1956 International 350 Utility".
The conversion is very easy. You just need to find to adaptor arms, one for each side, and a bracket for the top link. You will see in one of the pictures that my top link bracket actually bolts right to the tractor. I have also seen ones that bolt to the top cross member of the fast hitch assembly.
You can buy the arms new on this site, or watch eBay for a used set. They are pretty common, so you should not have much trouble finding a set. Figure to spend $100 - $200 for used arms and bracket, or $250 - $300 for new arms & bracket.
If you need more pictures, let me know.
Joe
jmauss
04-11-2006 16:24:12
third party image
