C-281
Maple Springs
04-11-2006 03:34:33
I may need a block for my W450: does anyone know which tractors used this block, so I know what to scrounge for in a yard near here (where many donors are not disassembled)?
Thanks, as always.
Mark
randy hall
04-11-2006 13:12:49
 Re: C-281 in reply to Maple Springs, 04-11-2006 03:34:33
i have a 400 and a 450 block that i could fix you up with. i am located in ohio.
cowboy red.
04-11-2006 09:15:44
i am 80% sure you can run thin wall sleeves in the 264 or dont run any sleeves in the 248 to obtain the 4 1/8 bore.
chadd
04-11-2006 05:01:47
Unfortuately for you, no other tractors used that block but the W-450 and the Farmall 450 and possibly the late 400's (s/n above 31239). The late model T6-61 crawlers also used it. I am not sure if you could overbore a C-248 or a C-264 to that size or not. I am sure someone else can give you more information. Good luck.
