IH 404 PTO problem
JD Foreman
04-11-2006 03:44:25
Good Morning everyone,
The PTO is trying to disengage on my IH 404 and it make a good bit of chatter when the going gets tough. I've been able to hold the lever at a slightly different position and it will stay for a while but it's not consistent. I can also push the PTO output shaft in and out about a 1/2 inch.
Do you think it's a worn gear or just a bushing?
Do I need to completely remove the PTO drive assembly to do anything to it?
What's a good hydraulic fluid for this application?
Thanks,
JD Foreman
