130 Grill Bottom
joe/mass
04-11-2006 11:25:46
Missing the bottom piece of the front grill assembly for my 130 Farmall. Are there any other models that have the same bottom that can be used? Trying to find another grill seems impossible.
Thanks Joe
Hugh MacKay
04-11-2006 17:32:53
 Re: 130 Grill Bottom in reply to joe/mass, 04-11-2006 11:25:46
Joe: Chadd is right any 100 or 130 will fit as will 200 and 230 with slight modification. Having said that, I doubt if you find a used one. The sheet metal on those 4 models did not stand the test of time near as well as the letter series did, thus the pool to draw from is not great.
You may be best off looking at new reproduction sheet metal. The grill of my 130 is not great, have been keeping my eye open for a use one close to 10 years now, and never saw any worth bringing home.
Joe/Mass
04-11-2006 19:01:21
 Re: 130 Grill Bottom in reply to Hugh MacKay, 04-11-2006 17:32:53
I have an old (2yrs)parts catalog from one of the known suppliers who listed a reproduction piece for the bottom, but when I called they stated that it was no longer being produced. I guess I will keep looking.
Thanks for reply's....Joe
Hugh MacKay
04-12-2006 05:18:52
 Re: 130 Grill Bottom in reply to Joe/Mass, 04-11-2006 19:01:21
Joe: Your right, I just checked a 2006 catelogue I have. They have the actual grill for 130 but not the sheet metal around it. Just one of the perrils of thos low production tractors. I see the piece your looking for is still available for letter series tractors. I notice they list A and SA but not C or SC. That doesn't make sence as the two are the same except for cutout around steering box on the offset.
chadd
04-11-2006 12:07:20
Farmall and International 100 and 130 should be very similar and should have the same grill assembly. A 200's or a 230's might also fit, but it would be less likely.
