adding a PTO to a W1256
tom rich
04-11-2006 15:45:25
Hello, my question is this..... ..is it possible to add a PTO unit to a factory PTO delete 1256 wheatland..... are the internal components in there , or is the entire PTO drive system missing? There is a W1256 on a sale coming up, and I could sure use it if a PTO could be added on..... ....Thanks for your input.
tom
the tractor vet
04-11-2006 16:28:38
 Re: adding a PTO to a W1256 in reply to tom rich, 04-11-2006 15:45:25
Well if it has live hdy. then everything But the PTO shaft and unit is there so you would need the input shaft and coupler and a complet PTo unit off any 706- 1066-1466 plus the linkage and lever . And you will have around a grad in getting all this stuff plus a rebuild of the PTO as i would never put in a used unit with out first doing a total rebuild .
