Flat belt gear box seal replacement
RIVER BOTTOM FA
04-11-2006 18:06:51
Tractor vet pulled bolts out of out put bearing retainer and removed the output shaft looks like gear and bearings are pressed onto shaft at the end of the shaft was a thick flat washer with two 3/8 fine thread bolts and fold over locks removed them and couldn't get gear and bearing to move is heat the answer or do I need to take in to the shop at work and put it in the press or is there a better way of removing the gear and bearings to replace seal. Thank you for any help RIVER BOTTOM FARMER
Wayne Swenson
04-11-2006 20:49:32
 Re: Flat belt gear box seal replacement in reply to RIVER BOTTOM FARMER, 04-11-2006 18:06:51
Long post!
My 2 sons & I just re-did 2 gearcases for their belt pulleys on their "H"s".
Remove three capscrews under the pulley mounting flange and the shaft, spacers, & bevel gear will all slide out with a bit of assistance.
Remove the cap screw on the end of the shaft and all the parts can be pulled off.
I was able to obtain replacement bearings at no cost by going to an electric motor rebuilding shop. If my memory is corect you need a 6210 & 6208 bearing for the drive shaft. Remove any shields so the bearing will now lube itself from the transmission oil. Thoroughly clean all old grease residue before installing the used bearing. Factory bearings run $50 or so for the big one so it can be an expensive affair to replace them. NAPA wanted $45 for the 6210 size.
I have a Case/IH dealer in town (Fergus Falls, MN) so otained the new seal, felt dust washer, and mounting gasket from them at a very reasonable cost.
Carefully clean the metal spacers and put a VERY light coating of silicone on them just before assembly. Don"t mix up the cap screws from the drive gear cover with the shaft cover; they are longer (don"t ask how I found out) and will not compress the spacers under the pulley flange.
On the drive gear shaft, just remove the 3 cap screws and pull the unit out. Remove 2 fine threaded cap screws & take the bevel gear & bearing off. It is a 6206 size. Watch out for the shift lever plunger & spring as they will jump out if the lever is moved too far. And this will happen as you clean the gearcase. If you need to replace the steel plug in the back of the gearcase, IH doesn"t have it any more. Go to an automotive parts rebuilder and get a 1 3/16" soft plug; it can be deeper (longer) than original. Put the spring & plunger back in place, set the large drive gear on the shift lever. Clean & lightly silicone the spacers and reassemble. The 2 long bolts had copper washers but a dab of silicone will work. Be sure to put them in place in the gearcase BEFORE you slip it into place on the tractor. They won"t go in later unless you remove the gas tank or pull the gearcase back out. (I know, experience is a great teacher)
It goes without saying to carefully scrape all old gasket residue off before reassembly. Careful use of a 10" or 12" mill file will do wonders. Use it as a draw file ( sideways motion, not forward & back) to locate any high spots on the metal casting also.
I now have 2 belt pulley gearcases that work just like new at a very minimal cost. Sorry for the long post, I was a Vocational Engines instructor in my past life and just can"t quit teaching!!
Good luck.
the tractor vet
04-11-2006 19:55:36
Don't know as i have never fixed one and ok ya'll can shoot me as if any tractors that i ever had had one on it it got taken off and throwen away as it was not needed and was in the way and was extra weight that i did not need . And the last time that i can remember useing a flat belt was when my uncle had hog for a few years and he would grind feed on and Old even way back then grinder mill mounted up in his barn off to one side and there was a door made just for the belt to go thru and a flat spot on the barn bridge for the tractor to set on .
