farmhand loader on 300/400 fit H?
combinekid
04-11-2006 19:14:15
at a local tractor dealer there is a rather dilapidated old farmall 300 or 400. I can't be sure cause all the tin is removed an there are no numbers on it. The tractor has a farmhand loader that has a pto driven hydrolic pump. The loader looks to be ok except for a few oil leaks. I was wondering if the loader would fit on my farmall H? Are farmhand loaders any good? Also approx how much are they worth? Thanks a bunch!
Nat 2
04-12-2006 08:24:03
 Re: farmhand loader on 300/400 fit H? in reply to combinekid, 04-11-2006 19:14:15
You can tell if it's a 300 or 400 by the angle of the steering shaft up to the steering wheel. A 300 will have quite a steep angle, while a 400 will be almost flat.
The 300 and H have the same frame width, so the loader will bolt right on.
Rick/Oasis ID
04-12-2006 06:04:43
My 300 has the same PTO drive Farmhand on it and it works great. I don't know about the swap to a H.
lekander883
04-11-2006 19:59:30
My H has a farmhand loader on it. Looks like they were ment to be!
Ia Roy
04-11-2006 19:49:25
I remember more than 40 years ago dad took the loader off the H and put it on the 400 because it had a better hydraulic pump and he was moving some dirt into the barn. Also the extra weight and power didn't hurt.
