water pump leaking on farmall H
combinekid
04-11-2006 19:31:51
My water pump leaks out the end of the drive shaft. According to my Operators Manual it says that there is replacable packing in the end of the water pump. Since I have to replace my thermostat I thought I would try to fix the pump too. Were can I get the water pump packing? Does Case IH have it? Thanks for the help on all my questions.
Dellbertt
04-11-2006 20:27:02
 Re: water pump leaking on farmall H in reply to combinekid, 04-11-2006 19:31:51
There is a grease fitting on the pump to help keep it water tight. Im not saying it doesnt need repacking just make sure you have grease it routinely.
Dell
Nebraska Kirk
04-11-2006 20:15:28
Your Case IH dealer should have the packing in stock, if not, they can order it.
