kirk in ks,
04-11-2006 22:21:28
does anyone out there have a 3-16 little genius plow on steel wheel,s with chrome on blades,and wide flat left wheel? Man O Man,this thing is a piece of beef to say the least, Only way I could move it was pull it behind my pickup,and then turn wide as to not hit the tailgate with the raising arm,s, If anyone has a photo of their,s, Please post it,and I will see it,and then i can compare it to mine for redo work to make it look as it was when new in 1930,s, Also,I maneged to get it up off ground when i turned the left wheel around it popped the trip lever back into the notch on left wheel, I pushed the left lever up,and up it came So nice,and easy of course after I sprayed everything in WD-40 to loosen thing,s up, this thing still has all the original grease zerk,s,and is all complete, Except for the scraper,s on side,s of disc,s to keep them from plugging up in the furrow, i think I can find them with not too much trouble.
