Crank Pin removal from crankshaft
JohnG(TX)
04-12-2006 14:58:57
I am having trouble removing the pin from the front of the crankshaft from my 1929 Regular. There appears to be no set screw, like on my F-20. The pin was cut flush with the crank when the nut was removed. Should I try to drill it out or take it to a machine shop? Or, just get a bigger hammer and wail on it some more?
El Toro
04-13-2006 04:12:18
 Re: Crank Pin removal from crankshaft in reply to JohnG(TX), 04-12-2006 14:58:57
Have you tried using a punch that's just smaller than the pin to see if it will drive out? You would need a drill press to drill it straight. Hal
