300 Utility Hydraulic valve parts availability
CharleyFarmall
04-12-2006 17:45:32
The splines on the handle and the splined shaft are beyond use on my fasthitch valve. Does anyone know if they are available as new parts?? Also, I need another valve to add a remote- I am assuming that i need to call all the salvage yards.
Last, is there a way to plumb in regular valves instead??
Thanks
Charley
CharleyFarmall
04-13-2006 06:39:57
 Re: 300 Utility Hydraulic valve parts availability in reply to CharleyFarmall, 04-12-2006 17:45:32
Thanks - I suspected that would be the problem. Someone has already partly drilled it and messed it up a bit but I think I can fix it.
old
04-12-2006 18:24:58
We ran in to that problem last year. The dealer said no parts. We drilled and put in a cotter pin to fix the problem. Been that way for more then a year with no problems
