Order Farmall Cub Parts Online
Cub Hydraulics
Farmall Ed
04-12-2006 18:58:13
I put a belly mower on my Cub today for the first time. Everything went pretty good until I tried the lift, It will go all the way up and of course down,but any setting in the middle it constantly hunts.Any ideas would be appreciated. Also what kind of fluid is supposed to be in this unit, it looks like engine oil in it now. Thanks Ed
Phlogiston
04-12-2006 19:48:02
 Re: Cub Hydraulics in reply to Farmall Ed, 04-12-2006 18:58:13
Hy-Tran Ultra is what needs to be in the unit. If it hunts it may need to be rebuilt. Drain the old fluid out and then refill to the bottom of the fill plug. If that does not work, make sure you take the number off the side of the unit when you go to your Case/IH dealer since there is more than one kit. Directions come with the kit. Be careful removing the screen. Keep everything as clean as you can. Dip all O-rings in Hy-Tran before installation. You can do it.
Phlogiston.
