Hydraulic Question
Steve KS
04-13-2006 08:54:11
Hello,
I need a valve for a loader on my 706 which has the high output pump w/ 17 gpm. My question: I found a joystick valve but it"s only rated for 14 gpm, will that cause any problems or just won"t cycle as fast?
Janicholson
04-13-2006 14:06:30
 Re: Hydraulic Question in reply to Steve KS, 04-13-2006 08:54:11
It will work, However the system will not work to the speed it would with a higher rated valve. Other factors may be the lines, fittings, hoses, and cylinders. Each affects the total flow. Give it a try, if it is not in a high demand gotta keep working situation, it will probably be fine, (my opinion)
JimN
Steve KS
04-13-2006 14:41:02
 Re: Hydraulic Question in reply to Janicholson, 04-13-2006 14:06:30
Thanks Jim!
I don"t need to win any races w/ it and it will only see intermittent use - so it should be fine.
