BE CAREFUL WORKING ON THE TRACTORS
Thomas Windsor
04-13-2006 15:17:49
Well, I am broken hearted today. My 70 year old friend, I am 65, was killed today doing what he and I like to do...to work on and restore these old tractors.
This is what he did...
He has an Ford 8N with a bush hog on it. For some reason he backed the tractor into the shop, raised the bush hog and put blocks under it and then turned the tractor off. He stuck his upper body up under the bush hog--he had a pipe wrench up under there..I am thinking that he was going to tighten something up. The blocks kicked out from under the bush hog and it settled across his throat and neck...he was found still warm but gone...he had his cell phone in his hand trying to call for help....Guys...be careful.
TW
Ida Red
04-14-2006 12:11:12
 Re: BE CAREFUL WORKING ON THE TRACTORS in reply to Thomas Windsor, 04-13-2006 15:17:49
Thomas sorry to hear about your good buddy and his terrible accident. Red
Ida Red
04-14-2006 12:07:19
Don't be in a HURRY.Don't work when you are over tired. Take a look in the front of any old IH operator's manual and you will find many good 'cartoon form safely tips' that still apply. I am posting a set of these on the wall of my shop. Red
El Toro
04-14-2006 08:12:10
People that use a bumper jack and then crawl under their cars are flirting with serious injury or even death. There was incident it where I worked, but in a different section where they up loaded 120mm artillery rounds with more powder to see if the gun would withstand the pressure.
This has been done for years without any problems.
They remove the primer with a spanner wrench and add more powder and reinstall the primer with the
same wrench until snug, then they used an air wrench to torque it.
This man had his own way of of doing this, he used the air wrench to remove the primer and to reinstall it. Had been warned not to do that many times. On this day he was doing the same
procedure and he was in a hurry to finish before lunch so he and his girlfriend could go eat.
We heard a large explosion that was near us, but they're always firing guns so we didn't pay much attention until we saw firetrucks and ambulances
heading that way. He and a co-worker were both killed, his girlfriend had stepped out to go to the bathroom a few minutes before the blast.
The safety office conducted a test to see who was at fault. They took a shell without any powder or propellant and used an air wrench similar to
one used on the explosion to remove the primer.
It was cherry red when removed. A photographer
that I knew was called to the scene to video and photograph the test cell. He said he didn't eat for a week. Hal
davpal
04-13-2006 20:47:23
That is too bad. I think about all the dumb things I have done with brush hogs. I usually pull the 9n in line in a shallow ditch we have if I have to look under it. That way the brush hog is down, the tractor wont roll and I have some room under it. I have since bought a forklift truck and I stand the mower decks upright and chain and double chain them and work on them standing up. I can see how it could easily hurt or kill you though. Sorry.
souNdguy
04-13-2006 20:21:01
Wow.. the worst part is that a 20$ set of limit chains would have saved him...
Soundguy
Levi K
04-13-2006 19:42:58
Wow, you think it'll never happen to you or your friends
Pete7
04-13-2006 19:08:13
Sorry to hear of your loss. Thank you for the reminder to be safe. I know I'll keep it in mind as I'm working. Can't think safety too much and it's all to easy to forget for just a second or two.
Pete
John A
04-13-2006 18:17:34
Thomas, I add my sorrow for your loss. And for his family too. Our prayers to HIM is what will get Ya'll through it at this time.
Later,
John A.
Jaybird2
04-13-2006 18:02:30
Thomas, Thank you for taking the time to share this with us. It's all we can ask that at least one person would take heed and prevent another similar tragedy. Thoughts and prayers are with you and yours. -Jay
Paul Shuler
04-13-2006 17:34:27
last spring I thought I would sharpen my blades on the belly mower . Pulled the front wheels of the H up on a 6x6 block. Went to wrenching under the deck and I felt the tractor move. I came flying out to find the block had shifted on the gravel. I was lucky, never again will I be so careless. I am so sorry to here about your friends death. My prayers are with his family
MagMan
04-13-2006 16:58:33
Sorry to hear that Tom, I will try to think about stuff like that while doing spring repairs. JON
Loren in Iowa
04-13-2006 16:32:32
Tom-That's a tough one. You've made us all think about keeping safety #1.
Nebraska Cowman
04-13-2006 16:22:44
Sorry to hear that Tom.
Dan in Ore
04-13-2006 15:36:49
Sorry to hear about the loss.
Had a gentleman locally several years ago that was working under a hay baler and the tire blew out. He was found crushed under the baler.
You just can't be too careful.
Dan
Wayne_In_Illinois
04-13-2006 15:30:06
Sorry to hear of your loss.Shame that it only takes a split second of a mistake to be deadly.I agree everyone needs to practice safety first when working on anything.Because the life you save my be your own.
Once again I'm sorry for the loss of your friend and my heart goes out to those affected by this!
jmauss
04-13-2006 16:00:23
 Re: BE CAREFUL WORKING ON THE TRACTORS in reply to Wayne_In_Illinois, 04-13-2006 15:30:06
My prayers are with you, your friend, and any family that he had. What a sad story. Just goes to show that anything can happen, even if you think you are taking the appropriate cautions. Hopefully your note will make the rest of us think about safety a little bit more.
Joe
