Sorry to keep bugging you guys! B-Tires
DJL
04-14-2006 12:54:48
I've talked around this topic a little in the past, but never got any definitive direction. It's about commitment time on the rear tires of my 1941 Farmall B project. Got the engine done, about wrapped up on the rear final drive/axle seals, just some odds and ends left and body/paint.
This tractor still has the original matched set of old-style Firestone Field and Road's on the back, with the closed center pattern. Great tread left, but normal weathering and cracking. I know I might be able to help the small cracks and the cosmetics with Miller's tire paint. However, both tires have a few small chunks out of the sidewalls, and they seem to be pretty brittle. Is there a way to restore/refurbish these so I can keep the original look? Does anyone revulcanize or "redip" their tires? Any help would be greatly appreciated!
Thanks
DJL
Charles McNelly III
04-14-2006 16:48:25
 Re: Sorry to keep bugging you guys! B-Tires in reply to DJL, 04-14-2006 12:54:48
Hi DJL, I have a 47 B. I'm fixing to tear in the rearend to replace the seals. How much endplay did you have on the outer axle? I have about 1/16". Don't know if this is normal. How much compression do you have on your motor? Did you go with pop ups?
Charles
evielboweviel
04-14-2006 16:35:55
buy some shoegoo used to repair tennis shoes and fill all the cracks. run high air pressure so the sidwalls don't flex and you will get some years out of them
Ron
