Carb Trouble?
purduepete
04-14-2006 20:30:20
I just got a new carb on my M and it idles well, but when u pull back on the throttle over half way it starts to die. Do the tractor gods have it out for me, or is there a simple solution. Thanks for your help!!!
Brownie 45
04-15-2006 04:18:41
 Re: Carb Trouble? in reply to purduepete, 04-14-2006 20:30:20
Try opening the load jet found at lower front on the carb , 1/2 turn at a time left_hand[open] & see if that helps.
RustyFarmall
04-15-2006 08:34:31
 Re: Carb Trouble? in reply to Brownie 45, 04-15-2006 04:18:41
I agree, open that load screw up a bit. It"s not getting enough fuel.
old
04-14-2006 20:42:29
You may need to reset the govanor to that carb.
Jim Broughton
04-14-2006 20:38:39
When you hooked up the carb....did you connect the linkage to the governor? If that checks out OK...then check you needle valve settings and if that checks out...?? Good luck Jim
