c169 valve setting
Rick/Oasis ID
04-15-2006 13:37:21
What is the valve setting cold for the c169, my book does not show this engine. Thanks Rick
chuck ore
04-17-2006 07:54:17
 Re: c169 valve setting in reply to Rick/Oasis ID, 04-15-2006 13:37:21
I was just going to ask the same question Thanks El Toro
Rick/Oasis ID
04-15-2006 18:06:20
Thanks El Toro
El Toro
04-15-2006 15:23:08
It calls for .017"H, I would set them at .020" cold until you get it running then recheck them
later after you run it for awhile when the engine
is hot. Should be very close to .017". Hal
